Rex
Rex
How come I cant get OSD to show up on my TV? Ive pressed Amp on then OSD and nothing, Ive tried change to V1 or V2. I have already programmed :confused: my controller to the TV, so it should work.
joelincoln
If I understand you, you don't see any of the on-screen info from your receiver on your monitor, right?
Are you sure that your monitor is getting its video feed through the receiver?
My 2400 has the ability to adjust the amount of info on the screen. I forget if one of the choices is no OSD at all. But if so, have you turned off the OSD function on the receiver accidentally? This feature is controlled via the remote on my 2400 but I think yours may be different.
Rex
Rex
I will check the monitor hookup, and I noticed that the OSD is turned off but when I try to enable it, it wont do it.
