I recently bought a Yamaha YHT 585 home theater system. The receiver has two HDMI inputs and one HDMI output as well as component inputs/ouputs.
My questions is, can I hook up my XBOX 360 with component cables and still use the HDMI output to my TV? The reason I ask is because the owner's manual states that you must use HDMI inputs if you are using HDMI outputs. Is there anyway around this issue? My XBOX 360 doesn't have the HDMI port and therefore I am stuck using the component cables; however, I want to use HDMI cables for my TV, cable box, etc. If I am reading the owner's manual correctly then my entire setup has to use either HDMI or component and not a mixture of the two types.
Please help.
