Hello to all,
I am new here, i would like to have some help to make the good choice about some equipment i want to buy.
I have a Denon AVR 1706 receiver. It's quite old and does not have hdmi/wifi...I have 4 Triangle Elara LN01 on it and a sub.
Now, I would like to play local music and also stream qobuz hifi on these Triangle speakers (only both front ones for stereo)
I think about two possibilities, that are quite cheap : Chromecast audio and mostly Yamaha WXAD-10. For the CA, it's straight forward, i plug it into the optical input of my AV Receiver. But I heard that CA is sometimes problematic with FLAC audio files, and i do not want to convert all my local flac files. Is it true ?
Thus, which is the best way to plug the Yamaha WXAD-10 on my receiver ? There are Ext. In inputs, and "normal" analog input ? What would be the difference between them ?
If i understood well, if i plug it to ext. in inputs, the receiver acts only as an amp, there is no signal processing done, but i could not modify bass or treble, only the volume, it is right ?
And, if i plug it into the "normal" analog inputs, i don't see what would happened because the digital to analog conversion would be done once with the Yamaha DAC and then, the signal goes through all the AV Receiver surround circuitry, for processing. In this case i would not hear the Yamaha "sound". It's like the receiver would defeat the Yamaha sound processing and apply its own processing, no ?
Could you please telle me if my thinking is correct ?
Thanks a lot
