Yamaha DVD-S2500 DVD Player
With its combination of superior sound and picture quality and array of technical features, the DVD-S2500B in an impressive addition to Yamaha’s DVD player range.
At A Glance
The first thing you’ll notice about the DVD-S2500 is its sturdy build quality and sleek, minimalist looks. Weighing in at around twice as much as the entry DVD players, build quality was obviously a key criterion when designing this machine. As a higher quality DVD model, the DVD-S2500 is designed to sit on top of Yamaha A/V Receivers such as the RX-V2500 or RX-V1500. Its sleek aluminium front panel complements the Receiver to the extent that it resembles a combined unit.
NTSC/PAL Progressive Scan
The DVD-S2500 offers progressive scan for both NTSC (US) and PAL (Aust.) video formats. This ensures maximum resolution from DVD’s and a smoother, more film-like image when viewed with a compatible display. The 216 MHz, 12-bit video DAC’s allow the Yamaha to have superior blacks and colour definition than ‘cheaper’ alternatives.
Disc Compatibility
One of the highlights of the DVD-S2500 is the inclusion of high quality playback of two new audio formats, DVD-Audio and SACD. Both offer superior sound quality over a standard DVD or CD, while capable of utilizing all 5.1 channels in a recording. Having both formats included, ensures compatibility regardless of which format dominates in future.
In addition to DVD-Audio and SACD, the DVD-S2500 plays back most optical discs formats on the market, including the latest version of MP3 CDs (multi-session), VCD discs, both formats of recordable DVD’s and of course, Audio CD’s, including copies.
The Latest Digital Outputs
The latest buzz word in the Audio/Visual scene is HDMI. HDMI (High Definition Multimedia Interface) is currently used to provide a digital image to the latest projectors and other high quality displays. Since there is no digital to analogue conversion, signal integrity is preserved, allowing a superior image. Other information, such as picture settings or aspect control can be sent via this one cable as well. Of course, when we start to see AV receivers start supporting this format, this one cable can carry digital audio formats as well. Naturally, the DVD-S2500 includes this feature, and Yamaha and other A/V receivers will start to support this feature sometime in 2005.
As well as HDMI, the DVD-S2500 also supports i.Link (IEEE1394). This provides a digital connection for DVD-Audio, SACD and other high quality audio sources. This allows the use of one digital cable, instead of the usual six analogue cables required.
Main Specifications:
Disc Compatibility: SA-CD, DVD-Audio, DVD-Video, VCD, SVCD, Audio CD, MP3, DVD+RW/+R, DVD-RW/-R, CD-R/RW
VIDEO PERFORMANCE: Video D/A Converter 216MHz/12-bit
AUDIO PERFORMANCE: Audio D/A Converter 192kHz/24-bit
Signal-to-Noise Ratio: 115 dB
Frequency Response:
CD: 2—20kHz
DVD: 48kHz Sampling: 2—22kHz
DVD: 96kHz Sampling: 2—44kHz
Dynamic Range: SACD: 107 dB / DVD: 103 dB
Harmonic Distortion + Noise at 1kHz: 0.0015%
Dimensions: (W x H x D) 435 x 100 x 314 mm
Weight: 5.6 kg
Warranty: 2-Years
