Corry
Yamaha RXV 2500 problems... HELP !
I have been reading these forums for years and I would like to thank you for all the information you guys provide on these forums.
I finally got a YAMMY RXV 2500 and I couldn't be happier.
The sound quality is totally amazing.
I moved from a Sony ES GX909 with ProLogic surround. The Sony still works fine and I was (still happy) with it after 10-11 years...
Here is my scenario:
I have a 7.1 speaker setup in a room of aprox 18x30.
The speakers are all Mirage:
2 Mirage floor standers - OM12
4 Mirage OMNI - Omni FX
1 Mirage OMNI - Omni CC
1 Mirage SWR - BPSi 150
The sound is just amazing with this setup.
The only issue I have is when I use the STEREO - 7 CH and I turn up the volume... around -15db the display on the Yamaha blinks/dims at the same rate with the Bass...
It is really loud at this level and maybe will not use this as a regular listening level but in case of large parties the volume may need to be raised above the -15db...
I tried various setup options from Large speakers to SML speakers... Bass out on SWR, both , etc...
Currently the Yammy is set at 8ohm.
What could be the issue? Is the Yammy not powerful enough to supply the Mirage's ?
What setup adjustments should I try?
Thanks!
Corry
Thanks!
Corry
