Yamaha RXS600 power protection activated
marlon.921
Hi guys just want help from expert of yamaha audio receiver, I accidentally plug it to 220v which causes the safety power protection activated, according to the manual, any body know how to de deactivate the power protection
Thanks
Thanks
How did you manage to do that? I presume the receiver has a 110 volt plug attached to it. If that is a 110 volt receiver, and you plugged it into a 220 volt supply, then that receiver is now damaged beyond repair.
Perhaps he blew a fuse.
Possible but unlikely a he said it went into protection. A fuse would likely not blow quick enough for an event like that. It is worth opening it up thought to check for blown fuses.
