Yamaha RX-Z9 with SF Cremonas?
U
Unregistered
Guest
I hope this doesn't seem too naive a question, but we're about to outfit a living room/home theater, and the time has come for some decisions. The room is 28'x18', with a 14' peaked ceiling, 5700 ft3, and the front soundstage will be situated along the short wall. Because of a doorway on one side and a piano on the other, the speakers can only be positioned about 8' apart, although our main listening position will be about 14' from the speakers. Right now, for aesthetic and sound reasons (about equal measure of each) we're planning on going with Sonus Faber for a 7.1 system, with Cremonas and Cremona Center in front, Cremona Auditors on the side, and Walls behind.
What I would hope to get in electronics in addition to the basics would be 7.1 processing (DPL IIx or equivalent), and ideally room EQ. Unfortunately, few separates have these features, Lexicon and Meridian being two. I've considered the Lexicon MC-12, and could stretch for this, but ever since its introduction I've followed the discussion on the Yamaha RX-Z9, and have been intrigued all along.
Of course, every salesperson I've dealt with has stressed that with an $8000 speaker like the Cremona (or others in that range), I'd be crazy to go with a receiver like the RX-Z9, that that would be audio heresy, that they've never heard of such a thing. My guess is they've never dealt with a receiver of the quality of the Z9, but truthfully, I don't know. So, my question is, would the Z9 and its amp section do a perfectly satisfactory job with the Cremonas, being used probably 80/20 for movies/ music, or is that a true mismatch?
My other question, just as naive: given that our speakers will be closer together than I'd prefer, would the use of "Presence" speakers with the Z9 placed above and to the sides of the mains add a sense of soundstage that would be desirable? Should that be part of the equation?
I've posed some of this to the local vendors of the Z9 (mainly the Good Guys, very few others carry this in the San Francisco Bay Area), but they just stare blankly, and say they have no experience (big help). I've love to audition the Z9 vs. separates like the Lexicon, but good luck arranging that.
So I'm turning to this forum, which seems to have as much experience with the Z9 as anyone, for advice.
Thanks for your patience with this ridiculously long post!
Brian
av_phile
Admittedly the Z9 has excellent digital processing features that can enhance your HT experience. So it can work as an excellent processor/preamp instead of going into separates in the preamp category. But for power amplification, I would suggest you get separates. The moderators on this forum will most likely give a thumbs up on the Z9 as receivers are most preferred here, not separates. They even opine that receivers and separates don't sound any different. But that's for you to decide. In my opnion, if you can afford to go for power separates like the Lexicon, Bryston, Krell, Aragon, do so. And leave the receivers to those who like simple things. You sound like you can go the complex route with a 7.1 and those expensive Sonus Faber Cremonas all around. Cremonas may just as well sound good on any receiver. But separates offer the most flexible route when powering up different channels. For me, a receiver would be an underkill for those speakers. But that's just me.
Brian
I wonder if those sales people have a financial interest in their suggestions ;)
The kind of receiver or separate components you get should depend on the speaker, its impedance and its sensitivity. Your room will have a definite impact on the speakers, guaranteed!
You have a large room to fill with sound.
The speakers will need to perform well at higher volume levels which you cannot assume that they will. Physics will dictate how loud they need to play so you get a certain level at the listening position 14 ft away.
If you have a speaker with easy impedance and is sensitive, you need less power at normal levels and less peak power for the transients. And if you want loud levels normally, you will need a lot of power for the peaks.
Receivers and separates may vary in the amount of power capability and maybe the ability to drive difficult speaker loads, not much else. And, not all separates are equally capable.
Perhaps you need to examin your needs, your speakers capability as your room is a fixed quantity.
Most likely that Z9 may be sufficient but I am not familiar with the speakers capabilities.
Are you adding a sub?
You also need to be aware of human bias when comparing componets as you proposed if you could. Small volume differences between components will indicate itself as one being better, the louder one. So, very close level matching is the first order of business, using the same speakers, of course.
Second, you still have human bias even with volumes matched as needed. The visual que, the knowledge of componets being listened to will bias a person without their knowledge and this bias cannot be turned on or off.
Hence, some sort of blind comparison is needed without outside influence from others.
U
Unregistered
Guest
ThanInquiring Minds Want To KnowKslACX scv
ks for your replies, guysE
U
Unregistered
Guest
Sorry, that last bit of gibberish is because I had just finished a lengthy post, and in finishing it I hit some key that seemed to erase it. I was trying to duplicate my actions to see what went wrong, and something else went wrong. How embarrassing. Ain't that life. Anyway, what I was trying to say:
Thanks for your replies, guys.
The Cremonas are 4 ohm, 90 dB sensitivity speakers, not hugely difficult to drive, as I understand it. I do profess limited understanding, though, as this weekend we were listening to JMLab Diva Utopia speakers with a SimAudio 200W/channel 5 channel amp, and while listening to "Rhapsody In Blue" at pretty high levels repeated clicking and popping occurred at the high dynamic passages, which the salesperson translated as meaning that clipping had occurred and a significantly more powerful (and thereby more expensive) amp was required. This, despite the fact that he had selected that amp for the demo, the JMLabs are listed at 90 dB at 8 ohm, and the web site states that 200 wpc is the "maximum power handling for a musical program". So I'm confused. Is it truly trial and error to see if a particular combination of speaker and receiver/amp will work, or can one rely somewhat upon the specs (like with the Yamaha)?
Yes, I'll be using a sub, although that's another story as Sumiko (which imports Sonus Faber) recommends dedicating a REL sub to the fronts which are run full range, and then letting the rest of the speakers be set to LARGE and relying on their own capabilities, unless one dedicates a sub to each set of speakers (one to the center channel, one to the sides, one to the rears). I'm currently leaning to setting all speakers to SMALL and crossing over to one or more subs, however.
Hey, has anyone used the Presence speakers? I'm still curious as to whether these convey a significant advantage, which if everything else works out, would be a nice feature for movie viewing. To date, I (and everyone I've talked to) think I'd be silly to go for 9.1, but the idea still intrigues me.
At this point I'm being pulled in the direction of the Lexicon out of uncertainty (and the ability to afford it), unless someone with experience with the Z9 and alternatives (possibly Gene, who wrote the review for Audioholics) would be able to give the true bottom line as to relative capabilities of the routes I'm considering. That is, someone who could say "The Z9 has evolved to a point where separates no longer convey a significant advantage, other than possessing certain processing features (if one needs them) or the ability to upgrade (if one needs that)".
And if I decide to go with the Z9 or Lexicon as a pre-pro, does anyone know what would be a good amp to go with the Cremonas? Is it really like selecting the right wine to go with Vichyssoise, as some (like those at Audio Asylum) seem to suggest?
Sorry for the long post, but I've got questions, and Inquiring Minds Want To Know.
Which is where I started, before my last attempt disappeared, which was God's way of letting me know that my posts are too long.
Brian
U
Unregistered
Guest
I just thought I might be of some help in your decision. You see I was in your boat just a few weeks ago. I had a B & K 507 and wanted some features on the Yamaha RX-Z9. So I went and demoed the Z9. It was an amazing piece of equipment.
Would I say that this reciever cannot hold pace with seperates is yet to be seen. I really think this box can hold its own with anything you throw at it. I actually traded in my 507 for the Z9. If you are looking for seperates the B & K seperates/receivers are wonderful sounding boxes. Form my comparisons of seperates vs receivers, It think its a different design strategy. My feeling is that seperates put your source more at the speaker, and that receivers put the source more in the room.
I have the other sumiko line, the vienna acoustics, and the fronts are 4 ohm and the rest are 6 ohm. I have listened to the Z9 at what I would consider loud levels (-15 on the display) and also the B & K at the same volume level. Both are very similar in noise defining room filling sound. The yamaha does run warmer then the b & K did, but as far as presence goes they are both sweet sounding boxes.
The worst thing about these boards is that everyone has there own opinion of what good music/movies should sound like. The other thing that you will get with the yamaha is the DSP's and they are in a league of there own. You won't find these on most seperates because they are out there for the purity of the sound reproduction.
Oh another piece of information for you concerning the room size, my room is about 22 x 17 with cathedrial ceilings and an open wall the the rest of the house and believe me there is no problem filling the house with sound and noise defining levels. Some will say that the yamaha misleads you with power, and while true the 170Wpc is high, that amount that it drops down to is a mute point unless you want to listen to your music and moives in your back yard or from your neighbors house.
My main concern was that I would give up sound quality from the B & K to go to the yamaha. Well that is not a concern anymore. The sounds is wonderful. The only thing that lacks is the manaul, it could be more descriptive, although not hard to get control of.
Another cool feature is that the channels have a 9-10 band equalizer that you can utilize for each of the channels to tune your tastes. There are tons of toys within this box the keep you busy for months, that is if you like tweaking. I could go on. I would say that if you get the yamaha you will not be disappointed at all.
Yamahaluver
Yamahaluver
I have the Z-9 and I also have some real good Yamaha seperate power amps and can tell you that the Z-9's amp section comes pretty close to the already excellent Yamaha seperates so by all means go ahead and get them with your SF Cremonas, it is a match made in heaven.
gene
gene
Audioholics Master Chief
Administrator
I can personally vouch for the Z9 sound quality. My home theater just doesn't sound the same without it :( Amp section is superb, DSP processing is exceptional (if that sort of thing is your bag). I can't wait for the next Z series Receiver from Yamaha!
BTW both my listening tests and measurements confirmed that the Z9 is truly a powerhouse as far as receivers go and can handle reasonably efficient 4 ohm loads (>89dB SPL @ 1 watt/meter) for most home theater environments.
Yamaha RX-Z9 Power Measurements
av_phile
I would suggest you asked the salesguy to have your Cremonas demoed with the Z9 for you to make a more personal assessment. In my experience, 4-ohm loads are not in the province of many Japanese mass consumer products. There are exceptions, but they mostly belong to the separates category and the high end series of these brands.
If you have a relatively large room, I would suggest using multiple subs, especially if you plan to cross all speakers to SMALL. That way you won't lose out on bass directionality which becomes apparent at high crossover points, say around 100hz.
You can always try them out. I haven't.
If you read the z9 reviews in this forum, that's precisely the moderators' point - that receivers like the z9 have come to give separates a run for their money. (It often makes me suspicious if they have any fiduciary connections with these HT receiver makers. In the same way they are suspicious if I have fiduciary interest with the makers of separates. :p ) Obviously from my posts, I do not subscribe to such nonsense. But like I said, do take the time to audition so you can discover for yourself. Personally, all-in-one solutions invite Murphy's LAw more readily than separates. I am not questioning the quality control of Yamaha or any brand like what some nitwit in another thread have laughably put in my mouth. I am merely pointing out that the more complex a gear is, the more chances of failure. Simple. And at the slightest failure in any component of a receiver, I would hate to pull such a hefty monster out of its rack and haul it all the way to the service center, leaving me with nothing to play with, no amp, no tuner, no preamp, no processor. Separates, while admittedly having complex interconnections, provide a degree of flexibility that allows the owner to mix and match and isolate problems more easily by their specialized componentry. Murphy's law also applies, no doubt, but its threat is more spread. I know of some audiophiles who even have separate DTS decoders, DD/DPL decoders, DSP processors, 5 mono linestage preamps and 5 power monoblocks that give them so much freedom to mix and match. And they can add/subtract channels anytime. A failure in one box won't leave them entirely cold. But a failure in a receiver could.
Pundits in this forum might tell you that amplifiers all sound the same. Even receivers and separate amps sound the same, according to them. To a certain extent, I can agree, above a certain price point. Not below. Too many compromises in parts and circuit design can deliver technical differences among recievers and amps in the mass market category. While it is entirely possible that low-to-mid end speakers mated with these mass-fi products will not reveal their sonic difference, I have had the opportunity to listen to some mass product receivers like a Pioneer and a Yamaha flagship mated to a B&W Nautilus and Martin Logan speakers. Compared to how they sounded on a Bryston and Meridian separates, these mass market products sounded pathetically thin and two-dimensional.
I do not entirely agree that mating speakers with amps is like selecting vintage wines to go with the viands. That may be so for tube amps which can be picky. But for SS amps, especially the more powerful and neutral ones, I see no problem mating them with any speakers of note. There is some case to be made about coloured amps being mated properly with similarly colored speakers. Like a bass deficient amp sounding better on a boomy speaker or vice versa. But that's for colored amps and speakers that are common among mass market products. With most fine separate amps and speakers that are neutral, transparent, linear and acurate, matching is the least consideration. Personally, I'd stick with any of those powerful neutral amps that can drive difficult or low loads down to 2 ohms. That way, anytime you decide to use those speciality low impedance speakers, you'd have no problem. I'd shy away from those mass market products in your case. Since your Cremonas are 4-ohm rated, I'd go the safer route and get a Bryston, an Aragon or a Meridian, among others, all of whom are known to drive 4-ohm loads without difficulty. SOme even go down to 2 ohms. They have models that are multichannel, stereo, 3-channel or monoblocks.
But if i got it right that you are thinking of getting the Z9 as a preamp/procesor, I have no qualms about that. Like I said, the Z9 is an excellent digital processor. But I really wouldn't be too concerned about those bells and whistles, and presence channels. I am not aware of any DVD material out there that has this. And personally, the lesser the DSP processing, the purer the sonics can be by leaving untouched what the studio and director wanted their DVDs to sound like. 5.1 for me is enough. Going for matrixed 6.1 or 7.1 or processed 9.1 with those presence channels can be exciting for sure. And a novel listening experience. But I prefer to hear what the director wanted me to hear in my room. IF he had the film encoded in mono or 5.1, that's how I want to hear it. I've heard what a DSP can do to a mono soundtrack. Also to a stereo track turned 6.1. I am not exactly ecstatic about it. But that's just me, ofcourse.
Brian
You posts aren't really that long. IF you gotta make a point, length shouldn't matter. You should see some of my earlier posts. :D
That is hogwas. Please point to the post and sentence where this is so stated, thanks.
Its best not to make things up.
Shinerman
Shinerman
So, do you think all amplifiers sound the same or do you feel all amplifiers sound different? Under the same conditions of course.
Shinerman.
U
Unregistered
Guest
Thanks for all your opinions and experience! I find all of this extremely helpful, and this reassures me as to the quality and musicality of the Z9 and its amp section.
Hey Gene, come clean regarding the Presence speakers, if you don't mind. Are they part of the reason why you miss the Z9's DSP modes, and do you wish the Denon 5803 (or whatever you're using now) used them? Do they significantly contribute to the movie-watching experience, to the point where if you were to buy the Z9 you wouldn't even consider not putting them in, or are they an interesting feature which may or may not work and which you could take or leave? I ask because we'll decide whether to go ahead and install the Presence speakers based on what I can glean, and such gleaning is few and far between in this neck of the woods. No-one around here seems to have much experience in this regard, including the locals who sell the Z9.
Thanks again,
Brian
U
Unregistered
Guest
AV Phile, thanks for your well-reasoned response and insights. I didn't refer to its content in my last post, because I'd started that post and then got sidetracked for a couple hours, and then finished and posted it before I realized there was further discussion.
As you suggested, I'm strongly considering going with multiple subs, probably a larger LFE sub in the front of the room and two identical smaller stereo subs set into the room along the side walls. We'll see. What do you think of that arrangement?
As to amps, I value your analysis and suggestions, including regarding specific amps, which I'll look into.
As to separates vs. receivers, I don't see it so much as Murphy's Law, inasmuchas if I were to buy separates and either the amp or pre/pro went out, I still think I'd be up audio creek without a paddle, unless I had a spare amp or pre/pro to throw in there, which I don't anticipate having. And the weight of the Z9 doesn't intimidate me. So the inconvenience factor I think would be about equal. The advantage to separates for me would be greater upgradability (a hollow promise with some separates as I understand it, a real factor with a few), something that even receivers will probably move toward in the next 5 years; better processing/room Eq; or a better amp section, which again raises the question of what is sufficient in that regard, and what you gain by moving beyond just relative high-end sufficiency.
As to DSPs, my understanding is that for many movies DPLIIx and Logic 7 actually work quite well, and if one has the room, 7.1 is a good way to go, not detracting from but rather adding to the 5.1 or 6.1 encoded experience, which is somewhat artificial anyway. 9.1 is a different matter entirely, without a lot of available feedback, and that's why I've asked that question of those who may actually know. For music, at this point I have no idea if multichannel is a good idea or not. I'm sure that of the myriad Yamaha DSPs, one would never use more than a few.
And by the way, are you English or just an Anglophile? Something has "coloured" my perceptions in that regard.
Brian
Shinerman.
Some amp sound different, shown to be so by DBT, most sound the same, for same reason. Anyone can design a euphonic amp.
Shinerman.
In addition, I offer you this more recent DBT on two amps, three self appointed golden ear listeners
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&threadm=501fl6$ac3@oxy.rust.net&rnum=1&prev=/groups?q=sunshine+stereo+yamaha+abx+nousaine&hl=en&lr=&ie=UTF-8&oe=UTF-8&selm=501fl6%24ac3%40oxy.rust.net&rnum=1
OR, you can read this:
"Topological Analysis of Consumer Audio Electronics: Another Approach to Show that Modern Audio Electronics are Acoustically Transparent", Rich, David and Aczel, Peter, 99 AES Convention, 1995, Print #4053.
gene
gene
Administrator
I enjoy some of the DSP modes for concert DVD's and movies. The "Presence" speakers do add another dimension and help to preserve imaging of main speakers. At this point when trying to decide between the Z9 and 5803, I would wait a few more days :) We will be covering alot of new products including the new Denon AVR-5805 which promises to be Grandiose, though very pricey, BIG and heavy (almost 100lbs!) It should have enough power to make even AV_Phile happy :)
Rob Babcock
Rob Babcock
Moderator
I don't mean to hijack this thread, but your mention of Denon's new stuff reminded me that they're supposed to be unveiling a new line of Ht separates. Have you seen any info on them yet?
