Yamaha RX-V995 question
K
kretinus
Anyone know what event or events kick in the cooling fan? It spins up briefly when first powered up but I haven't seen it kick in after that, even when I'm running it hot enough that a cooling fan would be a good thing.
gene
gene
Audioholics Master Chief
Administrator
The cooling fan will only run during sustained high power output such as when your cranking a multi channel music or movie disc or running continuous power measurement tests like I often do :)
If the fan isn't coming on you simply aren't taxing the unit enough to heat up for it to kick in.
bandphan
bandphan
Mines still kicking strong, relagated to the bedroom, but its beefy amps keep going.
