It is clearly explained in the manual, which you can download for free from Yamaha's web site.
Those outputs are for recording analog sources. The receiver does not convert digital sources to analog for those outputs. If you want to record a digital source on your CD recorder, you should plug directly into the digital input on your CD recorder.
