desmo900rider said:
but I can't find any info on the Denon site about it's 4ohm capabilities...I've already talked to Yamaha about their piece being 4ohm stable...
Thoughts?
They did talk about it on their site.
They claim in the FAQ section:
"11) Can I use 4 ohm loudspeakers with my Denon receiver or power amplifier?
Yes, you certainly can. "
http://usa.denon.com/1854.asp#Q10
In the 2106 manual, page 8, they also warned that the protector circuit may activated if the unit is used for long period of time at high volumes when speakers with impedance of less than 4 ohms are used.
http://ca.denon.com/AVR2106_DFU_ownersmanual.pdf
So you can be sure that the 2106 can run 4 ohm speakers but not at high volumes for a long time especially if the impedance of the speakers can dip below 4 ohms. On the other hand, the unit should be fine and stable driving speakers that claim 4 ohm minimum but nominally 6 to 8 ohms. I suspect the same would apply to the Yamaha model, it is highly unlikely that any mid level receivers could drive 4 ohm (nominal, not minimum) speakers with ease.
