i see. so you CAN'T produce the low bass. i thought you said i didn't need subwoofers if I had real speaks. my mistake.
nobody said anything about waterlines leaking SPL. just the presence of the low frequencies that is at least audible with no distortion.
instead of soundstage, try accuracy ... accuracy in the sense that you are producing ALL the frequencies the mixer of the music intended for you to hear. (yes, i said music. not HT)
The subwoofer bass takes away from the Midbass and makes the Acurracy or soundstage ( just words , that mean the same ) muffled and muddy sounding , taking away from the depth of the soundstage . I didn't say i wasn't getting enough bass , I stated above i was still getting Sub bass ( which i can only feel @ some large volumes of wattage
) , If you have ever looked @ a Pair of SDA's you would indeed understand .
Even with my Tube system , i tryed to add a sub , it just took away from the soundstage depth and i found my SP3 (when warmed up for about 3/4 to 1 hour ) did just fine in the bass dept .
All im saying , its tough to get a Sub right for all recordings ( to much adjusting to get it right on ) . If its to much , pow , there goes your soundstage .
Like i said before , 2 channel its not important to use a Sub ( unless your using Sats ) .
So you don't think my Bryston 4B can not produce enough power to produce Bass ?
Are you saying my 2B's powered by a Bryston 4B can not produce Bass ?
( of course everything is set to flat )
