N
ninja12
I just bought my RX-V2500 yesterday. The set up was really a piece of cake. However, I do have a question because I got a little confused.
I used the mic to do the calibration. That was extremely helpful. However, at the very end, I received the screen that said "Measurement Over Successfully". Now, here is where I got confused. Above the message, I had the option to "Retry", "Detail", "Setup", and "Exit". I followed the manual, and I chose "Exit". Another screen appeared and I had the option to "Setup" or "Cancel". Below "Setup" or "Cancel", the question "Don't Setup?" appeared. However, the manual says "To set the measured values and exit, select Yes. To cancel the settings and exit, select No." However, I don't see the two options "Yes" or "No". So, what I did was to just hit "Exit" on the remote to leave the "Setup" or "Cancel" screen. It appears that the settings were saved.
Do you know what I have to do to get the "Yes" or "No" options to appear after the setup is done or is the manual wrong?
