Hi,
First, I have the Z9, but from the looks of it and what the manual says, they operate very similar. But this means I can’t confirm what I’m saying
I’ll see if it can help anyway:
First, I’m using this
manual as my reference.
To operate the Zone 2 power, or pretty much anything else to do with Zone 2, you must use the remote control and make sure that you have programmed that accordingly. (it’s pretty easy to do)
Have you done everything on pg. 73 – 74.
You must set up your remote as they tell you so that is has the functions to control Zone 2. The default is set so the remote is on YPC mode (See pg. 60, step 3). This is not what you want.
Once you have set up the remote as the manual suggests, you just go to the little screen where you select the source and scroll to Zone 2 and have that selected. That means now that your remote is now only operating Zone 2 features, so if you press the power button, it turns on/off Zone 2. If you select the DVD player, the little screen on the remote will show it is the Zone 2 DVD player. And then to go back to controlling you Main unit again, you now select SYSTEM as your source on the remote. On the Z9’s remote, if you scroll up one you get Zone 2, and if you scroll down one you get System, and that is regardless of what source you may have selected already, so they are pretty easy to switch between.
But as I said, all this, Turning ON/OFF Zone 2, controlling which Zone 2 source you want etc, is only able to be easily controlled via the remote, and if that is not set up accordingly you won’t get far. So See Pg. 60 of the manual I posted above, and then go to Pg. 73-74 and follow the instructions there.
Once you’ve done that, see what happens.
Let me know, and we’ll go from there
Cheers (hope i didn't confuse anything)
KJ
