<font color='#000000'>George: Thank you for your reply. Yes, I'm getting the same responses from my remote as you are. And my switched outlet is working properly.
The reason I though it was not working is I needed a trigger wire to go to my external amp, and was told to use an AC/DC adapter, but what I found is that the AC/DC adapter is holding the 12vdc current when the RX-V2400 is turned off so it was not triggering my external amp on and off. I’m now using the ‘control out’ on the back of the RX-V2400 and it’s triggering my amp perfectly.</font>
