Yamaha RX-A600 won't power on in HDMI-1.....
ple999
...and Yamaha Support says that's the way it is designed. I just bought the RX-A600 to replace my old Yamaha 5.1 in order to get the 7.2, Ethernet and especially the ARC to match our Samsung Smart TV. HDMI-1 is the only input in use (Comcast cable box). The TV has Netflix, Amazon, etc, built-in. The audio switches over automatically when switching from Cable to TV and back, just as it is supposed to with ARC. The problem is the unit powers up for a second in HDMI 1, right where I left it, then self-switches the input to AV2, the default setting for "TV Audio". The TV then senses that HDMI-1 is gone and switches output to its own speakers. Using the Yamaha remote, you must then select HDMI-1 as input so the TV can switch back to the receiver's surround sound. Yamaha says the unit is not designed to retain the HDMI-1 setting and there's no way to change that. My old one stayed where set. Having to use a second remote every time makes the wife crazy. Is there a 3rd-party remote that can be programmed to turn on the receiver AND switch it to HDMI-1? Do I just leave the receiver on all the time?
Pogre
Pogre
Now there's a first world problem if I ever heard one. :p
There are some good universal remotes out there. I've not used any myself, but you'll get some good suggestions here.
Welcome to ARC implementation. Harmony remotes are very easy to use, and nearly all gear is in their database, I'd suggest the 650 model.
Bucknekked
Bucknekked
The Harmony remotes do this without breaking a sweat. I've had Harmony multi-function, all world control for at least 10 years. One remote to rule them all. Its customizable and its easy enough even I could program it and even my wife uses it every day.
