I have a 7.4.1 system consisting of a Yamaha RX-a3060 receiver with Martin Logan Motion 40 fronts, a Martin Logan Motion 50 XT center, Martin Logan LX16 surrounds, and Martin Logan electromotion IC overhead atmos speakers. The receiver handles the system well without any issues but it requires an external power amplifier to power two of the speakers for the full 7.4.1 setup. I just purchased a used Yamaha M-40 power amplifier which has 500 watts of power and is capable of 3 channels A, B, and C. I hooked up the fronts to run through the M-40 amp and the rest of the system is powered by the receiver and when I tested it I only hear sound on the fronts when the amp has the levels at 0. When I turn the L and R levels up on the amp there is no sound. I think this is really strange and intuitively I would have thought that it would get louder if the levels are turned up. The other thing I wanted to do was basically bi-amp the connection using 4 connections from channel C to the front left tower speaker and 4 connections from channel B to the right front tower speaker coming from the amplifier but this doesn't work at all. Do anyone have any idea what the issue could be? The amp seems so easy with hardly any buttons. Maybe the amp is not powerful enough? Although I would think 500 watts would be perfectly fine for just two tower speakers. Any ideas would be appreciated. I have attached pics of the amp. Thanks.
