Recently, my dad was looking for a pair of speakers for my brother's birthday. He's always working on his computer, so I figured that a nice pair of speakers would be a good idea. I'm a Yamaha fan, and that is why I thought of buying him a pair of NS-B310 Bookshelf Speakers. And since his desk isn't so big, I needed to find something compact and these babies are just the right size. We went to Best Buy and gave them a try and, to our surprise, they sounded pretty good for a speaker with such a small footprint. It incorporates dual 3.1", so don't expect huge bass from then, but they do offer good mid-bass and high-frequency tones. Power handling goes up to 120W and frequency response ranges from 80 Hz - 35 kHz. This speaker is well built, it has a removable grille. It was just what we needed. So there you have it. If you are looking for a compact set of bookshelf speakers, check out these little fellows. It won't play extra loud, but they behave really well at moderate levels and, what's more important, they will fit our purpose just fine. Do we have any owners here?
DESIGN AND FEATURES:
- High Sound Quality.
- Designed to reproduce the full, dynamic sound of HD sources.
- Woofers use light aluminum cones for clear, high resolution bass sound.
- Gold-Plated Brass Extruded Terminals.
- Slim, precision-shaped cabinet with cool, high-tech sandblasted aluminum baffle front panel.
- Elegant design in a choice of three finishes to complement any interior.
- Easy placement anywhere.
SPECIFICATIONS:
- System Type: Full-range Accoustic Suspension.
- Woofers: Dual 3 1/8" Aluminum Cone.
- Frequency Response: 80 Hz - 35 kHz
- Sensitivity: 87 dB/2.83 V/1 m.
- Input Power (Maximum / Nominal): 120 W / 40 W.
- Impedance: 6 Ohms
- Product Dimensions (W x H x D): 4-3/16" x 7-7/8" x 5".
- Product Weight: 3.5 lbs./each
Price: $149.99/each.
Check this speaker out and tell us what you think!
