STRONGBADF1 said:
Hey look ! I got smart and e-mailed Yamaha. This is their reply:
Hi
When sending audio to speakers that are set to large we pass the full
band with to those speakers
Don
Wow, quick response back from Yamaha
Were you looking for Floor standing of Bookshelf for mains. Also how often would this be used for just music listening vs. Home theater use?
I listen to rock all the time too and if you dont mind a speaker thats a little brighter, Klipsch (sometimes knows as the ultimate party speaker b/c they are so efficient they can play loud on minimal power) could be a good route for the speakers, Maybe RF-25's for the mains and an RC-25 for the center. The four surrounds may differ depeding on your listening habits, more music probably want all book shelfs, more movies may want one set of bi-pole/di-pole speakers and one set of book shelves. Also you may want to go ceck out Paraidigm Performance series for the budget you have, awesome bang for your buck speakers (personally my favorite). With a good sub you shouldn't need those huge drivers like in your cervin vegas. Check out HSU or SVS subs for around 400 dollars you can get something that'll pound out those drums. Alot of ppl have had good luck with the BIC 12" sub as well.
Receiver side if you listen to rock music like most of us itll be really loud and your going to want a hefty receiver. The Yamaha 1500 is a great choice for a receiver, or you might check out something like the Pioneer 1015 ( think the pioneer is going for something like 500 dollars right now. A Marantz 7400 would probably do the job as well.
