YAMAHA HTR5790 vs. NAD T752
REL
pretty new at this, but facing a choice....Yamaha HTR 5790s or NAD T752....both are used with a warranty, not sure the age of these models, mainly used for home theater, both very close in price with the NAD being slightly less, ....HELP!!!, any opinions????
I'd go with the NAD just because I prefer their warm sound. It's also likely to have a better amp section, though I understand the 5890 is pretty decent for the price as well, so the 5790 may as well.
REL
pardon my ignorance...still on a steep learning curve!!, but what do you mean by warm sound??....does this mean that the yamaha has a tinny or harsh sound by comparison??/..thanks again
primary use is home theatre 90% of the time and only 5.1 at that....looking forward to more opinions
runninkyle17
runninkyle17
I may be wrong, but I think the amp section in the 5790 and 5890 are the same as the amp in the 657 and 757. The amp section in the 657 and 757 is exactly the same as the high end Yamahas (RX-V1500, 2500, etc.). I recently purchased a RX-V1400 and it is amazing. I knew it would be a good HT receiver, but my real suprise came with the musical aspect of the unit. It is by far the most natural and true receiver as far as music sound processing. The HT portion is exactly as I expected (even a little better actually). I have not heard any NAD receivers, but I know they have a good rep which usually goes a long way.
However, I can tell you that if you go with a Yammie you will not be disappointed. Just a suggestion, unless you absolutely are set on getting the 5790, I would look at the 657 and 757 or even the RX-V1500 (or 1400 if you can find one). They are all very close in specs (the 657 and 757 have no multiroom and no THX, but have the same amp and sound processing as the 1500). Just my $.02, I am sure you will be happy with either receiver.
Yamaha has been traditionally considered bright, generally putting more emphasis on the highs and midrange. In recent years, they seem to have moved to more of a neutral sound. NAD is considered warm, which tends to have a bit more pronounced bass and a smooth, pleasant sound. There aren't nearly as many dealers who carry NAD, but I'd try to listen to one if possible. Yamaha should be readily available in most places, so you should have no problem giving a similar model a listen, and decide which suits you better.
