Dvs5770
Thanks for the info on the 5770 DVD player. But why in the world isn't there a HDMI or DVI output on this thing? I think these high end players spend to much time in development and miss important features like DVI or HDMI out. For that matter all of the new receivers should have a DVI or HDMI out, a simple thing to do ( look at all of the new HD TVs).
For your consideration, here is a simple little Samsung with simialr features @ $200 and its out now. Samsung Progressive-Scan DVD Player with HD Upconversion via DVI - Silver Model: DVD-HD841
Plays DVD-Video, DVD-Audio, DVD-R/RW, DVD+R/RW, CD-DA, CD-R/RW, SVCD, SACD formats, as well as MP3-, WMA- and JPEG-encoded CDs
EZ View letter-box eliminator allows easy 1-touch selection from several DVD formats to fill your TV screen
Built-in Dolby Digital and DTS decoders
6-channel analog audio outputs for SACD, DVD-Audio, Dolby Digital and DTS playback to amplified audio systems with compatible multichannel connectivity
DVI video output eliminates video quality loss that results from analog-to-digital or digital-to-analog conversions
10-bit/27MHz video digital-to-analog converter
24-bit/192kHz audio digital-to-analog converter 10-second instant replay/instant skip function Picture zoom function DVI, component video, S-video and composite video outputs; optical and coaxial digital audio outputs; RCA analog audio outputs Universal remote
RLA said:
Hi
I have the RXV 1400 and the HTR 5790 sitting here as we speak
The only difference between the two are the RXV 1400 has 3 more DSP's
It has a hinged door on the front and it has different zone 2 configuration
other than that they are identical Board layout,DSP processor AMP and
Power supply are the same. This is the DVD player I would wait for
http://www.yamaha.com/yec/products/HTIB/DVS5770.htm This DVD player will be the best bang for the buck this summer It should start shipping Mid July and is Identical to the much anticipated S-1500
Hope this helps
