Yamaha HTR-5730 Digital Input
mdhanson
I have seen previous posts on here about being able to change the name of the inputs entirely due to the fact that the Yamaha has only 2 optical and 1 coax which are pre-labeled. My DTV only has a coax audio output, and the input on the receiver is labeled CD. How do I change the label entirely?
I know I am just a noob, but I could not find the noob answer referring to just the manual...
http://www.yamaha.com/copyyec/customer/manuals/HTR_5730.PDF
Takeereasy
Takeereasy
Let me start by saying good job for posting a link to the manual, very helpful. The answer is on pgs. 38 & 41, just explained poorly. You need to enter your set up menu by pushing amp to turn on the receiver, then set menu. Now use the down arrow to scroll down untill the word inputs shows up in the display. Now use the right and left arrows to toggle through your selections. What you want is to get to the digital coax, I believe it will be the third item in the list. Again use the up and down arrows to select the device you would like this input to be assigned to. In your case there is an option for DTV/CBL. Press a sound field button to exit. This post is the best I could figure with your manual. I hope it works for you, good luck.
mdhanson
Thanks alot,
Setup was a breeze with the way you explained it...
Takeereasy
Takeereasy
I'm happy to hear I helped. Finally one goes up in the plus column.
trevorgray
trevorgray
I want to know what the 5 fingers said to the face?
