Yamaha HTR-5063/RX-V567 No Audio on HDTV
peleliu
I just bought a Yamaha HTR-5063 (same as RX-V567). I cannot get sound from input AV1 hooked to my DVD player using Component Video and Digital Optical Audio out. The receiver is connected to my Panasonic HDTV using HDMI. HDTV works fine on HDMI from the cable box as does AV5 which is for Composite video/audio (yellow-white-red) when inputting the same DVD signals. I am trying to use analog to digital upscale with audio provided from the Optical Digital output of the DVD player. Here's the summary:
Using receiver AV1 input from DVD Player:
Component Video - Displays OK on HDTV
Optical Digital Audio - No sound on HDTV, but Signal Info Menu displays Dolby D, Sampling 48 KHz and Bitrate 224 kbps. If I stop the DVD the displayed info goes away. So the digital sound is making it to the receiver but doesn't get to the HDTV.
I do get sound when I input DVD Composite Video/Audio on AV5 input.
I waded through the Owner's Manual and tried everything I could think of. Am I missing something? Any help would be appreciated!!
