A-A-Ron,
Sounds like a likely cold solder joint or poor wiring connection to me; I experienced a similar problem in a passive sub I had replaced the crossover in. In my case, I found and re-soldered the bad joint and it was fine afterwards.
Step 1) Discount-Double-Check and reseat all speaker wiring connections (AVR and speaker side of each wire). If this fixes it the problem was a simple wiring connection problem (unlikely).
Step 2) Investigate - Is the problem in both/all speakers, or only one?
a) If only in one speaker the problem is either in that speaker or that channel in the v995;
- To isolate the problem do the following test: Swap the "suspect speaker" with another speaker in your system to see if the problem follows the "suspect" or not; if the problem follows you have your culprit speaker; if the problem stays the culprit is in that channel on the v995.
b) If in both/all speakers it is very likely in the v995 and possibly a bit more serious (lemon alert!).
- In this case, it could also be a bad potentiometer in the v995 volume circuit
Hope that helps a bit,
XEagleDriver
