Yamaha 7.1 receiver
Receiver
I have a Yamaha 7.1 RXV-757 receiver with a Bose Acustamas II series 10 speakers (5.1). Should I take back the 7.1 and get a 5.1 reciever? Or should I just purchase two more Bose speakers and hook them up directly to the receiver? Please help!
MDS
Just go into the setup menus and set the surround back channels to none. Just because a receiver has 7 channels of amplification doesn't mean you HAVE to have that many speakers. I have a 7.1 receiver but also only use 5.1 speakers.
Receiver
Yamaha 7.1 RX-V757
So it I set them to none, then the back speakers of the 5.1 speaker system get output from the side surround speakers?
One more question. How do I get all 5 speakers to play equally for music?
Thanks,
I am really green at this.
MDS
The number of channels and the number of speakers don't have to be the same. The receiver has various processing modes and the mode you use determines how the channels are mapped to the speakers.
Examples, rather than a lengthy explanation:
1. A normal 'redbook' music CD has two channels (left and right). Two channels is stereo.
- The receiver can send those 2 channels to two speakers if you put it in Stereo mode.
- The receiver can send those 2 channels to 5.1 speakers if you use a matrix decoder like Dolby ProLogic II or DTS:Neo6.
- The receiver can send those two channels to 6.1 speakers if you use a matrix mode like ProLogic IIx or DTS:Neo6. Pro Logic IIx can also turn 2 channel stereo into 7.1. [If you only have 5 speakers connected and indicated that in the receiver's setup, then PLIIx will not be available - only PLII]
2. A DVD-V (movie) has a Dolby Digital 5.1 track. There are 5.1 channels on the disc. The receiver will use the DD decoder to send each of the channels from the disc to each of the 5.1 speakers. If you had 7.1 speakers, you could use ProLogic IIx to play the 5.1 channels over 7.1 speakers. [There are currently no formats that contain 7.1 channels]
3. If you only have two speakers and tell the receiver that in the setup, when you play a disc with 5.1 channels, the receiver will downmix the 5.1 channels into 2 channels and play it over two speakers.
4. If you play a 5.1 source but tell the receiver you only have front left and right and 2 side surround speakers, but no center channel, the center channel will be folded into the left and right front channels.
There are dozens more possibilities. The key thing is that you tell the receiver which speakers are connected. Then you choose a processing mode (that is personal preference - I personally use PLII Music for pretty much everything - all sources, whether 2 channel or 5.1 play over all 5.1 speakers)
As far as making all the speakers play equally, that depends on what you mean. If you mean make all the channels sound equal in volume, that is done by calibrating the receiver with the internal test tones and that is another topic (search for it, you'll get lots of threads on the topic).
If you mean you want all the speakers to play regardless of the format of the source you are playing, then again it depends on which processing mode you choose. The receiver will automatically detect the format and choose the correct decoder for the common formats; eg if you play a DVD with a DD 5.1 track, it will automatically engage the DD decoder. You can of course change it to whatever you want at any time.
Receiver
Another question
Another thing that happened is this. I was supposed to get the RX-V657 and the Audio Visual Specialist rep said he was out an automatically sent out a RX-V757, charging me $100.00 more. He said it was worth every penny, because it had the capability to utilize components. Was he telling me a story to make a better sale or is he telling the truth? Please help!
When I mentioned equal was that all five speakers would be equal in sound volume when I play the radio or a CD. Is there a setting for this? on the RX-V757.
MDS
Being a higher model number the 757 is going to have a few more features than the 657. I don't know the differences between all of the Yamaha models like some others on the forum. I would go to the Yamaha website and download the manuals for each and compare if you really want to know.
The thing is if you ordered the 657 and the salesman decided for you that he would just send you the higher priced model and charge you extra then you have the right to refuse it. That's a pretty shady tactic if he didn't get your approval first. But I don't think you will be dissatisfied with the 757 if you originally liked the 657.
Read the manual and see if that model has YPAO. It is an auto-setup routine that will automatically perform the calibration for you. Whether it has that or not you can always do the calibration manually with the internal test tones and an SPL meter.
Mudcat
Mudcat
That model has a 7 channel stereo setting. Use that to get all speakers putting out sound at the same level. PS, get rid of those B{l}o{w}se speakers, they have the tightest frequency response of any speaker on the market somwhere between 300 Hz and 5000 Hz. Anything outside that is lost. There are threads and link to the quality of boooze all over this forum.
