mspivy
First time poster to this forum....newbie to Home Theater setup....any advice is very appreciated!!
I'm looking at setting up a HT in a house currently under construction. I've been looking pretty seriously at the Yamaha 5790 receiver as it seems to have the one main item I'm interested in and is in a price range that is compatible with my budget (under $500 for receiver). I need a receiver that will support dual room / dual source. (I want to be able to have the kids watching a movie in the family room while I'm on the back porch listening to a CD). I've seen one review that said I needed a separate amp to make this work (to have dual sources going at the same time)...is that accurate or can the receiver handle it on it own? Is this receiver highly regarded? Is there something else I should be looking at?
Also, any insight as to the speakers / sub I should match with the receiver would be great....I'm likely just going to setup a 5.1 system with the 2 rear speakers being "in ceiling" and the front speakers being on the shelf. I don't have any preference to brand, but my budget is what I think would be considered modest....I don't need (or want) a system that's really flashy...just one that sounds nice and supports dual room use.
Thanks!
Mike
Thanks!
Mike
