Yamaha 3900 & Z7 users xbox360 optical sound drop out help ?
Meridius
Hi all
I was woundering if there are any users of the yam 3900 or Z7 and have a xbox360 conected to the amp using optical ?
as i have and the odd time the amp drops the sound for a split second, i was woundering if any of you have the same problem as it does not do it on any other device i have.
is this normal as i have had 2 of these amps and 2 xboxs and just seems to do it ? i was woundering if i am the only one as i think its the xbox doing it as my other devices dont seem to have this effect.
also it seems to only do it once or twice in the first 5 mins to 10 mins and after thta its ok is it the amp or xbox anyone having simler problems and is there a fix ?
