A-S801 is something like an avr derived integrated amp but it does not have HDMI connections. Unless you have good use for it's USB DAC feature, you are better off with the HDMI equipped Onkyo TX-NR686. It is not a stereo receiver, it is a 7.1 AVR. So if you are open to AVRs, for $599, the Denon AVR-X3400H is a better value, and has preamp outputs that allows you to add an external power amp to your system if it becomes necessary.
