asethi
Question 1:
I am having two problems with the 2500. I just got my new 5.1 surround Energy C speakers and LMF1 sub. I did the auto setup and it says my center channel is incorrectly hooked meaning the polarity is wrong. I checked and it seems fine. Did it again and same problem. Did total of 3 times but the center channel works fine on movies and such. Should i be worried?
Question 2:
I have been testing movies with my Sony dvd player with the reciever and have noticed that on the display of the yamaha it shows a little display l.e.d show up when certain speakers are on i presume meaning if i have dts movie and put it on THX then L,R,Surr. L, Surr. R, and LMF will light up. Which is good. HOWEVER, if i change it to Neo something only L and R turn on. A lot of movies are in Dolby Digital 5.1 and if I put them in Neo, THX, or other modes only L and R light up on my reciever. Shouldnt they all be lit up???? Note that all speakers work no matter what mode it is in but it seems wierd that the LED's only show up when a DTS dvd is playing and its on THX mode. Thanks guys.
Question 2:
