Yam c750 remote code?
augerpro
Anyone know the remote control code for the c750? The 2 listed in my Yam rv1105 manual don't work.
Nomo
Nomo
The remote for my RXV1500 uses 0566.
Did you clear out the old code using the clear function before entering the new code?
Edit: scratch that second part. Did you reset it to default codes?
augerpro
I didn't see anything about clearing it in the manual. I'll recheck though. It was programmed to run my old sony dvd player so maybe default then going to the new code will work. Thanks for the help!
