It is usually b/c they can't control copying/ripping of the analog signal as tightly as they can control a digital signal (that whole DRM thing). So basically, from now on out, if it's higher resolution, hd anything, blah blah blah, ie. perceived to be "better" than before, you can guarantee they will try to make it digital so that they can control how you use the product.
