.....there it is....but I will change the first sentence to say, XLR is BEST used for long cable runs....microphone XLR inputs on the back of a mixer/head are low impedence inputs, and you can run a cord 100 yards....microphone 1/4 inch inputs on the back of a mixer/head are high impedence inputs, and you best not run a cord over about 35 feet, or you'll begin to hear noise distorting the voices....I'm going to step out on a limb and say XLR outputs and inputs on our stereo equipment are low impedence also, and RCA outputs and inputs are high impedence, but I wish someone would nail down that one with knowing truth....WMAX, GIT THAT MANGY BUTT IN HERE AND CLEAR THAT UP!!....if you have a choice with your pre-amp and amps, I would use the XLR cables, you can find them fairly cheap....if XLR is better for long runs, why wouldn't it be better for short, even if you don't think you can hear a difference?....correct, hillbilly reasoning best attainable barefooted.....once again, I offer two outlets for XLR cables that appear to be thick, quality aplenty, and inexpensive.....
http://www.cablestogo.com/product_list.asp?cat_id=2029&engine=adwords!654&keyword=(xlr+cables)
http://www.av-cables.net/pro-audio/pro-audio.html?OVRAW=xlr cables&OVKEY=xlr cables&OVMTC=standard
