Wafflesomd
So I noticed this on my Pioneer VSX-815, what exactly is it?
It's probly the Xover between the speakers and sub for the LFE out.Wafflesomd said:So I noticed this on my Pioneer VSX-815, what exactly is it?
yes, that is correctSheep said:It's probly the Xover between the speakers and sub for the LFE out.
FYI Waffles, Xover= crossover. This is the frequency where your receiver crosses over the signal from the subs to the other outputs. The standard choice is 80Hz.Sheep said:It's probly the Xover between the speakers and sub for the LFE out.
You DO have a manual, don't you?
SheepStar
Here ya go for the manual. Remember, Goggle is your friend.Wafflesomd said:No manual, it was an out of box buy.
LFE out? Sub out?
hence the name crossover, not say, filter.j_garcia said:The sounds do not roll off at 80Hz, they BEGIN to roll off at 80Hz if you use an 80Hz x-over; you will still get sound below and above that, though at a reduced output the further you get from the x-over.
Yah, I know....j_garcia said:A crossover is not a brick wall. The sounds do not roll off at 80Hz, they BEGIN to roll off at 80Hz if you use an 80Hz x-over; you will still get sound below and above that (depending on the high or low pass to which speaker - high pass to main speakers, low pass to sub), though at a reduced output the further you get from the x-over.
Are you planning on building a kit or buying parts and building your own sub? There's a lot more to it than just building a box and putting the driver in it. Your sub will need its own amp also.
Thanks, that's all I needed to know.j_garcia said:100% of 80Hz and below, plus some sound all the way up to about 200Hz.
On my receiver there is an independent setting for LFEs which I set at 120Hz because as I understand it, that is the upper cut of point used by the sound engineers for LFEs. The rest of my speakers are set to small and crossed over at 80Hz. You would need to read your manual to see how your receiver handles LFEs.Wafflesomd said:Yah, I know....
I don't think you guy's got me.
If I set the x.over to 80hz, what freq's will come out of the LFE?
