wyeing two sub outlets on yamaha v2095's
redd454
in my system, starting off, i have two v2095's, two set's of mains, the first set, ran from the first v2095, and my sub's, now since my main's woffer's will go below 90 hz, i chose the option of running boy sub's and main's both where, option avalible, on receiver, my question is, can i wye the second v2095 sub out, and set it the same way, to get the lower frequecy through second set of mains, wich also have lower frequency woffer's, or would this do some sort of damage
WaynePflughaupt
WaynePflughaupt
Hard to make heads or tails of that, but if you’re asking if you can use a single sub with two receivers, the answer is you can use a “y” to split an output, but it’s not a good idea to use one to combine two signals. It requires a summing network like this:
https://www.rdlnet.com/product.php?page=349
Regards,
Wayne A. Pflughaupt
redd454
ok wyane' i have 5 subs, 3 in front under tv, could i take the two outer sub's and run them from the second v2095, without wye connecting both receiver,s, safley?
