Search Results for "Thermafiber" at Menards
S Shrader Audioholic Nov 5, 2012 #2 Anybody? they only have 2 of these left at the local store, and i can get them for $30 each, if it will work, I would like to bag them up before they are gone.
Alex2507 Audioholic Slumlord Nov 5, 2012 #3 Yes you can use thermafiber for sound panels. I think around maybe 50 cents a square foot for 2 inch thickness might be right.
S Shrader Audioholic Nov 5, 2012 #4 Thanks alex, these are four inches thick 24x48 come in packs of five. Glad they will work, should have enough for wall panels, then double them up for the front corner bass traps.
