Woot Deal Pioneer Elite VSX-40 $279
hizzaah
$50 off amazon price..
Woot® : One Day, One Deal
Authorized for SquareTrade Extended Warranty
Warranty: 2 Year Pioneer
Condition: New
Features:
Four (4) HDMI inputs with full support for 3D video content (Blu-ray, broadcast and gaming). Send 1080p signals to your HD display for exceptional image quality for your entertainment sources
80W rated output power per channel @ 20Hz to 20kHz, 8 ohm (560W total)
Uses specific Dolby Digital and DTS codecs to reproduce an enveloping 7.1-channel surround sound experience. The unit decodes Dolby Digital EX, Dolby Pro Logic IIz, DTS-ES, and DTS Neo:6. It also decodes the following HD audio formats: Dolby TrueHD, Dolby Digital Plus and DTS-HD Master Audio
Compatible with Blu-ray HD audio, so it offers DTS-HD Master Audio technology and supports bitrates up to 24.5Mbps, 7.1 discrete channels of 96KHz/24-bit audio
Dolby Pro Logic IIz offers additional “front height” channels to fully immerse you in your movies, music and games. This helps to create a more spacious surround sound for a compelling experience, and also provides a wide range of choices for speaker positioning to optimize sound in almost any room
Front-panel USB 2.0 port lets you connect your iPad, iPod or iPhone. The included USB/video cable lets you instantly access music, videos, streaming content, and photos stored on your Apple devices and supports iTunes album art
Multiroom capability allows you to assign speaker outputs to another zone which is independently controllable
Advanced Sound Retriever technology improves the overall sound quality of compressed audio formats such as MP3, WMA, and AAC formats. It employs digital sound processing technology that helps bring CD quality sound back to compressed 2-channel audio by restoring sound pressure and smoothing jagged artifacts that occur after compression
Pioneer’s Multi-Channel Acoustic Calibration System (MCACC) is included with this receiver. This technology detects speakers, and then sets levels, delays and crossovers, as well as measuring room acoustics
Pioneer’s 192KHz/24-bit digital-to-analog converter performs outstanding multi-channel audio conversion. By executing an accurate sound-field reproduction and reducing analog noise in the signal path, it is capable of reproducing an enveloping audio signal that is unsurpassed
With its multi-channel Auto Level Control, this unit is capable of equalizing playback sound levels if each sound level varies with the music source recorded on your portable audio player
Connect via Bluetooth wireless connectivity to virtually any other A2DP profile Bluetooth devices like your Smartphone, laptop or digital music player to listen to music from these devices (adapter not included)
Capable of receiving Sirius Satellite digital radio, which provides 100% commercial-free 5.1-channel surround sound music of over 120 digital channels. To listen to Sirius radio programming, you would need a docking adapter/tuner (not included) and activation of Sirius service (not included)
Enhance the overall bass output by connecting an external powered subwoofer to the low-frequency RCA output
Enjoy your favorite radio broadcasts with surround sound processing, because this receiver offers a built-in AM/FM tuner with 30 presets
Additional Photos:
Front Ports
Rear Panel
Remote Control
Package Contents
Packaging
Specifications:
Amplifier:
Output: 80W x 7 (20Hz – 20kHz, THD 0.08% @ 8Ω FTC)
Channels: 7.1
Audio Processing:
Dolby Digital Plus: Yes
Dolby TrueHD: Yes
Dolby Digital EX: Yes
Dolby Pro Logic IIz: Yes
DTS-MD: Yes, Master Audio
DTS ES: Yes
DTS Neo:6: Yes
D/A Converter: 192kHz/24-bit
A/D Converter: 96kHz/24-bit
Convenience:
Speaker Selector: Yes
Multi Room/Source: Yes
AM/FM Tuner: 30 Station Presets
Remote Control: IR Wireless
Connectors:
Inputs: (4) HDMI
(2) Analog Audio
(2) Component Video
(5) Composite Video
(3) Digital Inputs (1 Coaxial, 2 Optical)
(1) FM Antenna
(1) AM Antenna
Outputs: (1) HDMI
(1) Analog Audio
(1) Component Video
(1) Composite Video
(7) Binding Post Speaker Terminals
(2) Front Height Speaker Terminals
(1)*Digital Output
(1) Subwoofer (RCA)
(1) Headphone Output
Other Ports: (1) Bluetooth Adapter Port (adapter not included)
(1) Sirius Satellite Port Input
(1) USB 2.0 Port (front)
(1) MCACC Setup Mic Jack
Video Input Conversion: Anchor Bay 1080p Video Scaler
General:
Power Requirements: 120V AC / 60Hz
Power Consumption: 550W
Dimensions: 17.13"(W)*x 6.61"(H)*x 14.27"(D)
Weight: 21.16 lbs
Apple Compatibility
In the box:
Pioneer Elite VSX-40 7.1-CH A/V Receiver
Remote Control
(2) AAA Batteries
iPod Cable
AM Loop Antenna
FM Wire Antenna
Setup Microphone
Operating Instructions
capricious
Thanks! That indeed is a very good deal. I was looking for one, and considered this a little while back. But i had to let this go since it didn't have pre-outs. But for someone who is looking for a simple receiver, this is very very good. It is a cut above the regular pioneer line.
