Alright, thanks for the advice.
Two new pieces of information:
a) I called Peavey, and they gave me the modern model # (these are relatively old speakers). The woofer is rated at 60W; they didn't have a record of the cabinets; also, they don't know the frequency range.
b) I checked out the other speakers in the box -- they're ALL the same speaker 12810PA, except for the horn. In other words, there are 4x60W speakers, connected in series from the crossover, and then a seperate circuit from the crossover to the horn. (4x60W == 240W output?? Or 60W output??)
I don't think your guess that the cabinets are (in this case) engineered for perfect audio output is correct; they seem primarily to be engineered for durability and ruggedness (metalled corners, carrying handles, etc etc).
So, given all this, what can I do in the way of "hacking" this to produce a better output? Is replacing the crossover a worthwhile exercise?
What if I change out the crossover, so that I have 3 circuits:
1 --> horn for the highs
1 --> 3x60W in series for the mid->low
1 --> ??? for the low
There would be room to add a couple of tweeters while I'm at it, if this would make things more balanced overall. If so, should I buy everything (subwoofers/tweeters) @60W, or would a higher wattage work just as well? And how do I find the crossover that I'd need for this configuration?
Does this sound sane? Or would you just buy Peavey's replacement speakers?
Thanks!
