"Wirless Connection problem" PLEASE HELP!!
G
Gatsby191
:confused: Trying to connect my playstation 3 wirelessly but it wont take signal it tells me my strength is 42% then not connected and back and forth. maybe someone can tell me how to get it right. i tried net gears wall plugged extenders and thats when i was able to get the 42% signal strength on and off. is there a minimun equpment requirement or am i doing something wrong, please help.
How are you doing this, via a home network radio router or how? For good digital inter connect 60% signal strength is about minimum. For uninterrupted streaming 70% or over is the goal, 90% or over is considered luxury.
Do you have a laptop that you can check the signal strength with by any chance? It could be the room that the PS3 or the router are in, or even the orientation/location of the router. Mine was initially at about 65%, so I relocated (by just 2 ft) and changed the orientation of my router and now I get 80-90% I still get disconnected every once in a while, but it usually comes right back and I have about the same connectivity with 3 laptops.
