wiring up more than two speakers to amp
theupsetter
hello folks
this may sound like a stupid question but i'm pretty stupid when it comes to things like this. i hope this question makes sense!
i do not simply plug my speakers into my amp as the speaker wires are bare, i have to screw them in and i'm looking to find out if i can screw more than one speaker into each connection as i would like to place speakers in my kitchen as well as have them in my lounge?
if anyone can enlighten me on this i would be very grateful.
OttoMatic
OttoMatic
Running more than one set of speakers in parallel from a single amp can sometimes put a strain on the amp that the amp won't like. This impedance is generally measured in ohms (though it's actually more complicated than that). Do you know if your speakers or amp specify anything about "ohms" or "impedance"?
What speakers and amp are you using?
Doing this can be a problem because of these impedances, but you can also get away with it, especially if you are not driving the speakers to loud volumes. Also, most recent technology amps and receivers will enter a protect mode in the event that you are encountering problems, so you may have an opportunity there to see if you having troubles.
The bottom line is this -- yes, it will work, but you may have amplifier power problems, especially at higher volumes. Personally, I would try it; indeed I have two pairs of speakers connected just as described to an older Kenwood receiver for "family room" and "patio" duty. No problems whatsoever.
Good luck!
theupsetter
thanks for that otto!
i don't know anything about "ohms" or "impedance" i'm afraid.
the amp is a 'cambridge audio intergrated amp' but the speakers i'm not sure about, the make is 'eltax'? i think. i've yet to purchase the second set of speakers i will be using along with my 'eltax'.
theupsetter
thanks for your help everyone, that's great. i'll have at look at the links.
