That's not bridging an amp.
a
JohnA said:
You need to make sure that the Amp can handle a 4 ohm load. What you need to do is take the (+L) to the (+) on the speaker and take the (-R) to the (-) on the speaker and then connect the amp (-L) to the amp(+R).
This will bridge the amp into mono. But make sure the amp can drive a 4ohm load.
That's trying to put both channels in series and it sounds kinda dangerous to me.
When you bridge an amp. you have circuitry on the front end that splits the signal in such a way that each amp handles half of the signal. When you connect the speakers, youi connect up the hot of one channel and the negative of the other channel. There is NO jumper between the unused terminals.
What he's doing is trying to combine the output of both channels. Amps don't like this and generally react exactly as this one did. He's lucky that it powered up again.
