BangThaGong
BangThaGong
I have a sub that has a 400 watt amp on it ,My reciever is only 100 WPC. My question is would it be better to run fronts off the sub or reciever? Also if connected to sub would the speakers get more power from sub or does it get the power from the reciever (100) WPC? Dont understand how that works thanks For any help
Midcow2
Midcow2
Usually the sub amp's 400 watts only drives the sub. The fronts should be connected to the receiver.
BangThaGong
BangThaGong
Ok Thanks . So the out puts on sub is kinda like a bypass then. Would it be ok to hook rears up to it or reciever? Sorry to ask again but not sure as of yet where everythings going to land,Just a basic idea .
Rickster71
Rickster71
Leave the surround speakers connected to the 100 watt amp.
Hook the sub to the 'Sub Out' connector on the amp.
The sub has it's own separate amp; it needs it to move that big driver at low frequencies.
All the sound levels will become equalized when you use the speaker level setup, or an SPL meter.
Boy, do I type slow...I was the first reply, when I started:D
BangThaGong
BangThaGong
LMAO Ok Thanks
