audio wiring
Sorry - I should have mentioned that -
I have audio interconnect (RCA) from Comcast STB Audio out to the Receiver's Audio In for Video 1 -
When using the receiver just to listen to the radio, the sound is massively higher - I have to turn it down to about 18 or so so it's not blowing your ears out - but when using the receiver for the cable audio, I have to turn it up to about 45 - and the volume number on the Sony receiver only goes to 60 -
Just can't figure out why this is happening - also, I am using the Sony speakers that came with that receiver - it was somewhat of a home theater in a box system but I still feel it should sound much better using the digital sound that should be coming from the cable set top box....so, I'm assuming I just don't have something connected correctly.
Should I perhaps be using the orange coaxial SPDIF from the cable box to the receiver? Or the optial link? My understanding is those are digital connections whereas I'm using analog with the audio interconnect, is this correct?
Thanks for any insight
Scott
