Wireless USB Music Connection
havinnoj
Guys do you know if there is something that will allow me to eliminate the 3.5m/RCA cable I use now to play music from a laptop through a stereo reciever and replace with a wireless device?
Adam
Adam
If you're looking for something small, then perhaps the ANYCOM BAR-10 Bluetooth Audio Receiver (in conjunction with a bluetooth dongle if you need to add bluetooth to your laptop). I came across it from doing a Google search, and I don't have any experience with it.
If you're just wondering in general if you can connect something to a USB port and stream music wirelessly to your receiver, there are other options.
Just something to get the thread going. Hopefully others will have some good ideas for you.
havinnoj
Thanks for the help guys - Is there a wireless router out there with music and laptop internet capability at the same time? Or do I need a music bridge and seperate wireless router for the internet?
Adam
Adam
I'm pretty sure that the Airport Express from Apple would do what you want.
havinnoj
Awesome I will check it out.
