Wireless Router Music nto Theater Sys.
Audioklepto
Audioklepto
Audiophiles,
I've been monitoring the beginners site for a while and haven't seen this question asked.
I am looking to buy a system in the near future. Have $1200 of so to invest. I'm interested in mainly listening to music, but will use it for movies and occasional gaming. It seems that one of the Denon receivers -pair of Pioneer SP-BS22,and a pair of floor speakers would be good but looking for ideas.
My music is mainly on a large capacity thumbdrive on a Netgear N600 so it is accessible to portable computers without my main computer being on.
I want to be able to access the digital music library from my router on a Home Theater system on another floor using the wireless network if possible. I could, if necessary, run a hard line to the system, but have no idea where to start. The router and computers have USB only and audio equipment uses HDMI.
Any ideas on a receiver/speaker system for mainly music (classical to rock) and a way to input the music?
Thanks much,
Audioklepto
jp_over
jp_over
I just bit the bullet and went with a dedicated PC with an HDMI output:
Echo Mini PC: See our Video Review by HD Nation on Revision
Using Windows 7, you can access your whole network.
There are some cheaper workarounds (Sonos and others) I just felt like nothing gave the full functionality of a PC. Also, you could add an HDMI card to one of your existing PCs, locate it next to the N600 & AVR, then use the network to stream.
BoredSysAdmin
BoredSysAdmin
Audiophiles,
Thanks much,
Audioklepto
Denon 1912 (for example) claims to support DLNA and same goes for your router which I assume is WNDR3700 (N600 is not model number, but a spec)
Now in Ideal world - dlna between two devices from different brands should work, but we are not there yet. Short version - It might work fine (especially for mp3 files) or might not
For wireless part - you'd need to get a wifi bridge like this one:
Newegg.com - TRENDnet TEW-637AP Wireless Easy-N-Upgrader 802.11b/g/n and 802.11e up to 300Mbps
Audioklepto
Audioklepto
- TRENDnet TEW-637AP Wireless Easy-N-Upgrader 802.11b/g/n and 802.11e up to 300Mbps]
Thanks so much for the info- a bridge and DLNA capability seems like the way to go. The router is model WNDR3400v2 by the way.
Thanks again
Audioklepto
G
Grador
Thanks again
Audioklepto
I've never really been thrilled with the compatibility and interface of receiver based streaming.
You may want to look at something like a WD TV Live. $80 on amazon, and has built in wifi so you wouldn't need the bridge.
BoredSysAdmin
BoredSysAdmin
This is also a decent option. Like I said DLNA is not always works right, but if limited to simple mp3 files it is more likely to work.
WD TV Live is a neat box and priced very attractively, but
a)I am not sure if his router can serve that usb stick using cifs/samba
b) wifi bridge can be helpful to connect other "smart" electronics to home network like "Smart" TV, BluRay player or game console if located at same location
