wire ferrules sizes Car/Auto Hifi?
This is more a home setup site but as long as the wire fits the ferrule should work, but you likely need lower gauge wire for a typical auto setup than home....
Mark E. Long
Mark E. Long
I use similar ferrules on my home built cables although they are made little better as in gauge specific And gold plated for what that’s worth . With that being said they do seem to make a better connection in banana plugs if you use the right crimper for the ferrules . It seems better than just bare wire .
I was wondering which wire ferrule sizes is most common in car hifi installations? :)
You don't need them and every part that comes between the wire and the device's terminals has a chance to degrade the signal.
If you want to base the installation on appearance and not worry about the sound, go ahead and use whatever looks good.
