will this system work?
  • Thread starter Thread starter the-fett
the-fett
It's become harder and harder to find a receiver that's rated to run a 4 ohm load these days. Technically, you can run an 8/6 ohm rated receiver into a 4 ohm load as long as you don't run full power.
If you do try to run that Pioneer at full power into 4 ohms, it doesn't have the current capacity to handle the demand and you will quite likely kill the receiver.
