Shockingly bad information from a Klipsch representative. With a 101 dB sensitivity rating, the RF-7 is one of the most efficient speakers on the market, which means it puts out a lot of volume for the amplifier power fed to it.
By contrast, sensitivity specs of most other speakers are commonly in the 85-89 dB range. Take a speaker with a 87 dB sensitivity rating as an example: Hook it up to your system, play it at a comfortable volume. Then disconnect it and hook up the Klipsch, and the sound level will be about 14 dB louder. Fourteen decibles!
Bottom line, you can run those speakers at ear-bleeding levels using only a fraction of the power your Z9 has. An outboard amplifier would be a waste of money.
Regards,
Wayne A. Pflughaupt
