Hey, everybody. I’m new here, so please...be gentle
I’m pretty decent w/ computer specs, but haven’t been able to get the hang of reading audio equipment stuff that well.
Been reading about how audio clipping could cause damage to speakers and was wondering should I be worried if I have the speakers below with a Sony str-dg820 (7x110 watts)? And I was worried about the fender ones for L/R. With them being below 110 – should I be worried about blowing/overheating them? Or would there be a config tweak to handle the differences?
Thanks for the help.
== center ==
JBL S-Center
Description: 3-Way dual 5-1/4" center
Maximum Recommended
Amplifier Power: 150W
Nominal Impedance: 8 Ohms
Sensitivity (2.83V/1m): 91dB
Frequency Response (–3dB): 75Hz – 20kHz
Crossover Frequencies: 800Hz, 3200Hz
== L/R ===
Black Fender® Passport PDP-1 Passive Speakers
Frequency Response: 100Hz - 20kHz (+/- 6dB)
Power Handling:
o 40 Watts (RS426B),
o 60 Watts (Program),
o 80 Watts (Peak).
Impedence: 8 ohm.
Low Frequency Source: Two 4" (102 mm), 4 ohm Speakers, with 1" (25 mm) Voice Coils.
High Frequency Source: One 1" (25 mm) Dome Tweeter, with 5/8" Voice Coil.
Sensitivity: 89dB, 1W-1meter.
Vertical Dispersion: 60 Degrees (at 5kHz).
Crossover Frequency: 3.5kHz.
