Will Audyssey detect 2nd sub with 2 outputs?
Cristofori
Cristofori
I have a Marantz SR-6005 with dual sub outputs. As of now I only have one 10'' sub but I plan to get another (maybe) in the future.
Will Audyssey be able to set up with the 2nd sub? There is something in the manual that indicates to me that it might, but I was told by someone on here a while back (can't remember the name) that the 2 subs wouldn't be in phase.
My question is if this receiver was designed to utilize dual subs, then why wouldn't they be in phase, and if they wouldn't, is there any point in investing in a 2nd sub?
GranteedEV
GranteedEV
IWill Audyssey be able to set up with the 2nd sub? There is something in the manual that indicates to me that it might, but I was told by someone on here a while back (can't remember the name) that the 2 subs wouldn't be in phase.
The subs wouldn't "necessarily" be in phase, depending on where you've got them placed. Commercial subs generally come with at least a 0/180 degree phase switch, and better ones have variable phase dials.
The thing about the SR6005's subwoofer output, is that they're supposedly not discrete. That is, the same signal is sent to both subs, rather than each sub EQ'd independantly.
This means that time delay or independant trim levels are not set. It's basically the equivalent of using a Y-splitter to use two subs. It can still work, but it won't be as optimized as having the right electronics properly isolate and calibrate the subwoofers' individual behaviour. The subs' combined behaviour is calibrated by Audyssey instead, presuming it's not seriously problematic cancelation between the subs.
Multiple subs are still recommended, although eventually you still might want to implement some signal processing in order to integrate the subs as best as you can and play with unconventional placements.
Cristofori
Cristofori
I haven't been able to find much specific info regarding the dual sub outputs, only that the manual recommends to keep the second sub at the same levels when doing Audyssey.
I don't understand why they would bother putting two sub outputs on the unit if it really isn't any different then using a Y-connector.
Thanks... I may play around with the sub EQ levels to see if any improvements can be made.
Jeff R.
My sub levels have never been set to the proper levels on my audyssey system. I always have to go and manually set to my liking. I have always heard the mic has a hard time with the low frequency in determining output level for the subwoofer channel.
It's usually better to buffer the output to two separate devices and they may have buffered these, to avoid using Y cords, which vary wildly in quality.
