Why Video Signal Through Receiver or PrePro?
DJE4MSU
<font color='#000000'>If my television or monitor is capable of accepting direct Component Video signal, or for that matter any video signal, what are the reasons for or advantages of running the video signal through an A/V receiver or PrePro?  I understand that an AUDIO signal may require processing for multi-channel distribution, but why the video input?  Thanks for your help and advice.</font>
aarond
<font color='#000000'>one word
Convenience
its easier to have the video follow the audio selected
i do not use mine for video switching, everything goes direct to monitor. i have the video out connected so i can use the on-screen menus
ok more than one word</font>
av_phile
<font color='#000000'>I agree For convinience and for the on-screen menu.  But I know of very few receivers that output the OSD via component video, at most via s-video.  The convinience part is more a functionof whether you have other sources, like VHS, or another DVD player (usually a back-up) that must share the same monitor.  So you only need to switch once to switch both audio and video to that source via the receiver.  Otherise, you have to do the selction on the monitor in addition to the receiver or pre-amp.
Also, i think the Krell HT pre-amp has a feature that allows you to adjust the black or grey levels of the video going though it,  Could be mistaken of the brand but am sure I read an ad about an HT preamp bieng able to do some video calibraton as well.
In my set-up, i prefer to route the video cables directly to the monitor.  Eliminates video switching noise that can enter the audio route in receivers.</font>
BuddTX
Ok, this thread is a little old, but it proves that I did a search before creating a new post!
In pondering over a new A/V receiver or a pre amp/pro, I am debating amongst myself, the importance of VIDEO switching in an A/V receiver.
I have some questions, but also some observations, hopefully my observations will educate others, or maybe just spark controvesery.
There is actually an AUDIO question also!
First, my observations:
1. Video via a Receiver or Pre amp/Pro is MORE CONVIENENT! this is either a plus or minus, depending on your thoughts, and the people that share the remote with you.
2. Video via a Receiver or Pre amp/Pro gives you more options to get the BEST VIDEO SIGNAL to your monitor. If your monitor only has one HDMI (or DVI) input, and your Sat dish, Cable, and DVD player all have either DVI or HDMI outs, ALL the video sources can benifit from using the BEST input/output connection. No argument here, this is a big plus.
3. Some people have reported distortion when using thir Receiver or Pre amp/Pro for video routing. As they say, YMMV.
4. More and more AV equipment has on screen setups that only work (duh!) when connected to a monitor.
Now for the questions:
Q1. Is there any signal proccessing and enhancements happening via the receiver such as
Upconverting
Filtering
Signal Boosting
Signal Enhancement?
Q2. Kind of related to Q1, is hooking up a lower source video in and having a higher source video out, such as a VCR RCA out to a HDMI IN, does that offer any advantages, other than less cables?
Q3. (The Audio question!) HDMI is DVI video + high speed (is it 7 channel? UPDATE- HDMI is actually 8 channel uncompressed audio!) digital audio. Will HDMI be considered to eventually be a universal input/output connector? Imagine having ONLY HDMI input/ outputs on all your devices, and only having ONE cable for every input or output that the device might need. (Like, will SACD and DVD-A eventually use HDMI outputs?
Q4. Given the option, is it better to go (for video only):
output device (say DVD)--> Receiver or Pre amp/Pro --> Monitor
or
input device (say DVD) --> Monitor
I would think that input device to Monitor would be cleaner and more accurate, but that depends on the answers to Q1 & 2.
Look forward to reading some comments!
