7.1, for right now, only takes a 6.1 signal and plays the center rear signal in 2 "center" rear speakers. The reason for this is supposedly better acoustic imaging. When you have one speaker directly behind you, your brain can may sometimes tell you those sounds are coming from infront of you (Making the center rear signal sound like it is coming from the center front speaker). By using two speakers and offsetting them from being directly behind you you have much better imaging and never get the confusion you may get from one speaker directly behind you. I read this is an article some where but I can't recall where right now or I would post it for all.
As for those who looking for "future compatibility." I don't really understand. Is this compatability meaning having the extra speaker because the receiver you buy right now, I assume, will only ever use the algorithms it currently has to decode the information from 6 surround channels then splitting the center rear into two speakers. Unless you can update these algorithms I don't believe you will ever be able to decode true 7.1 formats when they do come along.
Please someone correct me if I am wrong.
Also there are 6.1 formatted DVD's they are called DTS ES and DDEX
The following is a link to a list of these types of DVD's
DTS ES and DD EX
There are currently no actual 7.1 format DVD's
